3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
adding to a spline
1 REPLY 1
grue1970
272 Views, 1 Reply
adding to a spline
i would love to be able to add to a spline by shift+dragging on a vertex, adding a new segment. is something like this possible?
right now i basically have to create a whole other spline then attach it to an existing spline, then fuse & weld the vertices.
you know like you can shift+drag an open edge of a polygon to create a new polygon
3ds Max all versions past and present | GPU Rendering on 2 machines | Standard, MentalRay, MentalRay IRAY, IRAY+, VRAY, Arnold
1 REPLY 1
grue1970
in reply to: grue1970
wait a second... it looks like "create line" automatically welds the vertices!
EDIT: oh, it doesn't unless you turn on auto-weld.  ok well.  shift+drag would still be useful.
