3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
3dsMax 2019 control / ctrl remove not working. Cant even set a hot key for it
3 REPLIES 3
jrubinoX9C5K
675 Views, 3 Replies
Can't remove an edge cleanly (taking vets w/ it). I can only delete the edge then have to manually remove the vert's.
3 REPLIES 3
Hi @jrubinoX9C5K, thanks for your post here!  😁
Are you selecting Edges and using CTRL+Backspace hotkeys to remove the Edges and Vertices?
I am currently able to remove Edges cleanly in 3ds Max 2019 and 2020 using these commands. -- If for some reason this is no longer working as expected for you, could you try resetting the 3ds Max preferences to see if this helps?
Thanks so much and hope to hear from you soon!
Please Accept as Solution if a reply has helped resolved the issue or answered your question, to help others in the community.
Kindest regards,
Dominique Bouthillette
Principal Specialist, Industry Support & Escalation
Entertainment & Media Solutions
That fixed it. Thanks!
That is great news! And no problem at all, thanks for letting me know that worked for you. 😊
Kindest regards,
