Can't remove an edge cleanly (taking vets w/ it). I can only delete the edge then have to manually remove the vert's.
Solved by dominique.bouthillette. Go to Solution.
Hi @jrubinoX9C5K, thanks for your post here! 😁
Are you selecting Edges and using CTRL+Backspace hotkeys to remove the Edges and Vertices?
I am currently able to remove Edges cleanly in 3ds Max 2019 and 2020 using these commands. -- If for some reason this is no longer working as expected for you, could you try resetting the 3ds Max preferences to see if this helps?
Thanks so much and hope to hear from you soon!
That is great news! And no problem at all, thanks for letting me know that worked for you. 😊
