3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
3ds max won't let me pick custom section for sweep
2 REPLIES 2
775 Views, 2 Replies
So I'm not very experienced with this software but I am trying to create a mountain road with some small details like guardrails and such. I tried making the corners with the bend tool but it is a pain to use and I can never get the result that I want.
So I gave up with that and tried making them with the help of the line tool.
I created my line and made it curvy, just as I want the road to be. Next up I applied a sweep onto it and wanted to pick my pre-made road (it goes in a straight line) for my custom sweep, it however did not let me pick it.
I decided to then separate the road from the guardrail and it still would not let me.
Is there a way around it so that I can pick my road as a custom sweep?
If not then how else should I make this?
Tags (2)
2 REPLIES 2
Did you perhaps pick the path spline as custom cross-section? That`s not how the sweep-modifier works.
You add the sweep modifier to the path spline. Then you pick  the spline that defines the cross-section of the road as custom cross section.
Path orange spline, cross section is yellow:
oh I see, thank you
oh I see, thank you
