3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
3ds Max scale multiple vertices to a specific point
10 REPLIES 10
Message 1 of 11
6999 Views, 10 Replies
So here is my 3ds Max questions (currently using 2013).  I want to scale multiple vertices to the vertex circled in red in the image below. Be default the tool goes to the center of all selected verts. in Maya you pressed insert, moved the tool's pivot and just scaled. Is there any way to do this in Max?
I've tried moving working pivot to this location, but it appears the scale tool with just verts selected won't use working pivot (or object pivot for that matter). I've looks through multiple manuals and Google searches... This is so easy to do in Maya it's hard to believe it's not in Max somehow... any help would be great thanks!
Billy
10 REPLIES 10
Message 2 of 11
Steve_Curley
If you're trying to line them up vertically it's much easier to Move them than to try Scaling them.
Move Tool, Snaps (to Vertex only), Enable Axis Constraints in Snaps ON. Select a Vertex, click/drag on the approptiate Gizmo Handle and move the cursor over the Vertex you want to align to.
If you really want to use Scale, use the Select and non-uniform Scale tool, Use Selection Center. Select the vertices, select the Gizmo axis you want to scale in (click it, or use the appropriate Axis Constraints toolbar button), position the cursor over the vertex (snap to it) you want to be the center, click and drag to perform the Scale.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 11
Stefan_L
In this case - assuming you'd actually only like to move the vertices to the same Y coordinate like the circled one - you also could:
- deselect the circled vertex
- perform a non-uniform scale of the other vertices along Y axis to 0% via type-in (so they all line up)
- move them along the Y axis to the circled vertex (with vertex snap and axis constraint)
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
Message 4 of 11
ekahennequet
There is a way to it in Max that's better than Working Pivot, imo.
1. Make your selection without the circled vertex. Press Spacebar to Lock Selection.
2. Turn on 3D Snap, and make sure Vertex is checked in the Snap Settings.
3. Select Uniform or Non-Uniform scale depending on your need. Choose Use Transform Coordinate Center.
4. Mouse over to the vertex you want to scale about until a yellow cross appears. Click+drag the vertex.
Message 5 of 11
Stefan_L
in reply to: ekahennequet
I tried this, you'll have hard times if you want to scale the horizontal distance between "the circled vertex" and "the selected vertices" to zero, because mouse-on-screen scaling works in a non-linear way 😞
Stefan
Win7ProX64 SP1
Message 6 of 11
ekahennequet
in reply to: Stefan_L
Stefan, you're absolutely right about scaling to 0, and I wouldn't recommend it for that. Right-clicking the scale value in Transform Type-In is much faster. But often, I need to scale things not to zero, but about a specific point on the fly, and it works well. 🙂
Message 7 of 11
Why not just align the associated edges along the particular axis?
There's a useful maxscript that allows you to specify a vertex to align edges to.
http://www.scriptspot.com/3ds-max/scripts/straighten-edge
Message 8 of 11
ekahennequet
Billy can correct me if I'm wrong, but I believe the original poster was not looking for alignment or scale-to-zero tool. I attached an example problem showing what I think he meant.
Message 9 of 11
Thanks ekahennequet!
That was exactly it... turned out to be more steps then I was expecting, but figured it had to be possible!
Billy
Message 10 of 11
Ok, I see what the OP wanted now.  I was incorrect in my assumption of the goal.  Thank you for clearing that up.  Smiley Wink
Message 11 of 11
ekahennequet
I was just guessing, luxxeon. 🙂
You're welcome, Billy. 🙂
Cheers.
Technology Administrators
