3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
3ds Max garment maker problem
0 REPLIES 0
Message 1 of 1
360 Views, 0 Replies
  Hello everyone!
       I'm having a problem modelling some curtains with the garment maker.
  I am modelling my actual curtains at home which are ring top curtains. I simply want a 182cm x 165cm with 8 x 6cm diameter holes at the top. I create the splines needed, add the garment modifier and increase the density expecting my 8 holes to be there but what I get are 7 holes and the spline in the right corner isn't being used. I can even delete that spline and move the circles across and the same thing happens. Is this a bug? I moved the splines down to the bottom of the curtain and the same thing happens on the opposite corner.
   Is there a workaround for this? Am I doing something wrong? I can supply pictures or step by step if needed.
   Help!
    Mark
0 REPLIES 0
