Hello everyone!
I'm having a problem modelling some curtains with the garment maker.
I am modelling my actual curtains at home which are ring top curtains. I simply want a 182cm x 165cm with 8 x 6cm diameter holes at the top. I create the splines needed, add the garment modifier and increase the density expecting my 8 holes to be there but what I get are 7 holes and the spline in the right corner isn't being used. I can even delete that spline and move the circles across and the same thing happens. Is this a bug? I moved the splines down to the bottom of the curtain and the same thing happens on the opposite corner.
Is there a workaround for this? Am I doing something wrong? I can supply pictures or step by step if needed.
Help!
Mark
