the only reason why 3ds max crashes is because your computer cannot handle the amount of fragments that it is trying to render, you would need to reduce the fragments or add more memory so your computer can handle it, when you hit render then everything in your scene has to be calculated and rendered as you know, even the fastest computer with a high amount of ram can still crash
