AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Viewport display issues
Message 1 of 11
have 2 problems which are derailing me from completely a tutorial
1 vertices are not showing in front viewport
2. When i select and object ..it is highlighted in blue and I want to remove that
I get the same problem in both 3dsmax 2016 and 2017
Replies (10)
Message 2 of 11
Fadhil_Farook
To turn off Selection highlight got to CUSTOMIZE > PREFRENCES and uncheck SELECTION/PREVIEW HIGHLIGHTS (See Attachment -1).
For the vertex issue, does restarting max Solve the issue?
Message 3 of 11
for your asssitance with highlight issue...but the vertex problem is still an issue
Message 4 of 11
Fadhil_Farook
Is the case true for any other object that you create? Can you try checking it's object properties, or viewport configurations to see if anything is messing with the display?
Message 5 of 11
I checked both object properties and viewport config...and I don't see anything that would cause the problem ...not sure of what I should be looking for the vertices display properly in perspective, left views...but top view, front view don't display in vertex mode
Message 6 of 11
FadhilJust to clarify...I only get this problem when I am working from a background reference image mapped to a plane
Message 7 of 11
Fadhil_Farook
That shouldn't be a problem. Would you mind passing the file? Also which version of Max is it?
Message 8 of 11
Sure (see attached)
I'm using 3dsmax 2016
Message 9 of 11
Fadhil_Farook
I see what the problem is... Your Image plane is blocking it. You're keeping the Reference image before the object while your viewport is in SHADED mode, meaning you won't see through the object.
What you really should've done is placed the FRONT reference image at the furthest point (the back), not at the front although it's the front.
I've done this correction in your file, please check it out (Attachment -1).
Edited: Your
Message 10 of 11
Hey bro
Thanks a bunch Fadhil..really appreciate the help.
Message 11 of 11
thanks for reply. but its already off
