Texturing problem - to many edges
Spoiler
Hey guys, I need some help.
Ok, I created a simple house from 6 different walls, and than I select one wall and simple attached other walls to create one object.
Now I textured this, and I have some strange problems.
1.) Look at texture at top wall - it have strange rotate.
2.) Second picture - problem with broken texture on edge where 2 walls are intersect.
Tnx!!!
ehh I found solution.
First, my walls was not correct welded, so I make new.
And second, I forgot to turn UW map in modifer list, and I used multi object with ID numbers for wall texturing (example, ID 1 is outer wall (brick what you see), and ID 2 is inner wall).
Tomorow will be over this first project 😄
