Splines on Mesh not working properly (max 2024)
Alexx31
Alexx31
I select the object, but the spline tool is not working on it after the very first time using.
It worked only once at the beginning, later not at all. (Editable Poly)
Tried 30 Minutes...
It only works once, then if you work again on the object the pline tool becoes corrupt, even can't paint on grid.
(only "selected object" is already causing this=
Attached also my file:
If I work with this file, the spline tool is corrupt even after Reset. You will need to restart 3dsMax 2024.
Attached video
Alexx31
I found the issue of 3ds Max: If you delete the first created spline, it is not working anymore.
It keeps always the first generated spline as target for creation.
Actually it should produce each time a new spline. It's the same issue in Max 2022.
ads_czechoj
Hi Alex. I cannot reproduce this issue.  Please re-select the surface after reopening 3ds Mx. The Spline drawing tool remembers the selected surface only for one session. After saving the file and reopening it, the selected object's name remains, but to activate it, we must select (assign) the object again.
