Splines on Mesh not working properly (max 2024)
- Mute
- Permalink
- Report
I select the object, but the spline tool is not working on it after the very first time using.
It worked only once at the beginning, later not at all. (Editable Poly)
Tried 30 Minutes...
It only works once, then if you work again on the object the pline tool becoes corrupt, even can't paint on grid.
(only "selected object" is already causing this=
Attached also my file:
If I work with this file, the spline tool is corrupt even after Reset. You will need to restart 3dsMax 2024.
Attached video
