Right-Click to End Chamfer? (NOT Abort Chamfer)
miketruly
Message 1 of 1
miketruly
MAX2021
In MAX2021, if I:
1.  Create a cylinder.
2.  Convert the cylinder to an editable poly.
3.  Select some edges.
4.  Right-click to bring up the quad menu and choose 'Chamfer' and chamfer the edges.
5.  Right-click to exit the 'Chamfer' process... the newly create chamfers are REMOVED!!
I just want to exit the 'Chamfer' process and keep the chamfers I created... NOT remove the chamfers I just created.
In MAX2020 (and previous versions), this works as desired... with a right-click, the 'Chamfer' process is exited and newly created chamfers are preserved.
Is there a setting to make MAX2021 work as before?
Thanks!
Sincerely,
Mike Truly
Truly Media
www.trulymedia.com
Replies (0)
