Pro Cutter taking too much time
giacomo.piccardi
Observer Observer
giacomo.piccardi
Observer
Observer
I'm trying to cut a complex object made of more than 3 millions polygons using Pro Cutter. The cutter is quite more simple, around 3 thousand polygons.
I checked only "stock inside cutter". I did some tests with simpler object and it works as I want.
Basically like cutting a cake into several irregular pieces.
The problem is that Max is taking forever. I let Max calculate for hours but with no results. Suggestions? I am using 2023.
I can not simplify the models obviously.
RobH2
You may be doing something that takes so much calculation that it can't complete. Three million is a lot to divide up. Have you tried using Pro Optimizer to reduce it first than then using Pro Cutter?
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
giacomo.piccardi
Observer
Observer
I solved like this: split the "cake" before and then apply "subdivide adaptive option". In this way I have my pieces and all my polygons (actually triangles).
Thanks anyway!
RobH2
There you go. Sounds like a good method.
Rob Holmes
