Pro Cutter taking too much time
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to cut a complex object made of more than 3 millions polygons using Pro Cutter. The cutter is quite more simple, around 3 thousand polygons.
I checked only "stock inside cutter". I did some tests with simpler object and it works as I want.
Basically like cutting a cake into several irregular pieces.
The problem is that Max is taking forever. I let Max calculate for hours but with no results. Suggestions? I am using 2023.
I can not simplify the models obviously.
