Pixlation when Importing Autocad file to 3dsmax
hanya_khaled_ar07906
When I import autocad file to 3dsmax(2023) program the objects in 3dsmax look unatural like this after I use the extrude tool
By the way I the the unit in autocad is the same in the two programs is in meter
My device (intel i7 - nividia gtx 1060-16 ram)
RobH2
How far away from the orgin 0,0,0 is the mesh? If a long way, you need to move everything to the origin. Max does not have double precision calculations so it does not like it when Autocad sends something over that is 2 miles from the origin.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
rendermaster
Try high quality preview on viewport - Press SHIFT F3
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
