Pivot point not rotating
Hi all,
I have a spline which i rotated 45 degrees:
If i click on it i see a pivot point which isnt aligned with the spline:
I figured i could use "hierarchy" -> "affect pivot only" and "rotate" to rotate the pivot point:
As you can see a new pivot point was created which is aligned as how i would want it.
However.. after changing the pivot point i press right click and move to try my new pivot point but it just shows my old pivot point which isnt aligned:
My question is: Why does the pivot point pops back in his old position in stead of the new position I gave him with "affect pivot only"?
bob.bernstein
The pivot is controlled by the reference coordinator drop down.  While this gives you most of the options you may need, if you need a custom orientation, you can create a helper called tape, and align it how you want an axis to exist, then click "pick" in the drop down, and you should now have a custom setting in the drop down giving you your custom outcome.  [Right side of attached image]
In left side of attached image, I clicked on screen, and you see the pivot aligned to the screen.  Read help on this and mess with it.  You will get comfortable with it after a shot while.
