Move tool weird behaviour in perspective view (keeps snapping)
Hello, I have the same problem that was described here and here, but there are no any real solution in theese topics exept of "start a fresh project".
Is the behaviour like on the video a bug or is it some lovely feature that I need to turn off?
Note that i have no problem in Top (and any other orthographic view) but only in perspective, which is even weirder.
irishman_team_kilber
Try resetting the IU
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Resetting-3ds-Max-3ds-Ma...
also try adding the lastest service packs and hotfixes if you have not already done so link
https://knowledge.autodesk.com/support/3ds-max/downloads
laomusic_arts
Hi!
I just had this issue and here are some solutions:
If the Move tool in 3ds Max 2018 is always snapping, here’s how you can fix it:
1. Check Snaps Toggle (S Key)
  • Press S to toggle snapping on or off.
  • If snapping is on, you'll see the Snaps Toggle icon highlighted in the toolbar.
2. Check Snap Settings
  • Right-click the Snaps Toggle button (🔲) in the toolbar.
  • Ensure Grid and Snap Settings are configured correctly.
  • Try disabling Grid Points or any unnecessary snap options.
3. Check Constraints
  • Go to Main Toolbar > Constraints Dropdown (next to Select and Move).
  • Set it to None if it's on something like "Grid" or "Face".
4. Check Axis Constraints
  • Ensure you're not locked to a specific axis.
  • Try moving while holding Shift or changing the transform gizmo mode.
5. Reset User Preferences
  • If the issue persists, reset preferences:
    1. Close 3ds Max.
    2. Navigate to:
      C:\Users\YourUsername\AppData\Local\Autodesk\3dsMax\2018 - 64bit\
    3. Rename the ENU folder to ENU_old.
    4. Restart 3ds Max (it will create a new ENU folder with default settings).
I my case I just had to push "S" and "problem solved!
hope this helps others too!!
LAO
