Issues connecting polygons
Message 1 of 9
Hey I'm having issues connecting two different polygons, the only thing I could come up with is they're not grouped together but I tried grouping them and then I'm unable to select any polygons, what am I doing wrong?
Replies (8)
Message 2 of 9
irishman_team_kilber
if you attach them together then select the two polygon's and then choose bridge that will work
Message 3 of 9
That's the issue it will only allow me to select one polygon, I'm unable to click on the polygon I want to "bridge" to.
Message 4 of 9
if you attached both walls together then you beable to brige two poly together, In 3dsMax you can't bridge faces, that belongs to two different objects.
here is a script it called super poly bridge http://www.scriptspot.com/3ds-max/scripts/super-poly-bridge the tutorials are too.
side note i never convert down because you lose the option for max to automatically cut holes in walls for the doors and for windows, you will need to keep boolean which sc*** up the mesh.
Message 5 of 9
I understand that but it's only allowing me to select one polygon, I can't select the other that I want to bridge to.
Message 6 of 9
you need to upload the file if there is a copyright issue then an autodesk empolyee can take a look at it,
Message 7 of 9
Nevermind I got it, I wasn't connecting the assets.
Message 8 of 9
Richard.Vivanco
Maybe you press the space bar and lock the selection?
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Message 9 of 9
No I wasn't attaching all the items as one.
