AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
I can't add UV at modeling.
mintchocosuuki
Observer Observer
mintchocosuuki
Observer
Observer
The modeling file was first at home.
Then I bring the file at work and brought at home again.
 The UV was fine at work, but after I brought at home again, I couldn't see the UVs.
I thought it is because of the UV's saved place was different, so I checked and linked, but It dosen't show.
I also checked the show at viewport icon.
The main problem is the drag and drop UV function were not available.
I even erased the UV and added again, but the UV only shows the 'object color' colors.
Is there anyway to solve this problem?
RobH2
Are the Max versions the exact same with the same updates?
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
jibijib
Check you don't have the object in 'sub-object' mode with nothing selected inside.
