For that kind of image you have to sort of cross your fingers and find what you can. Most of what you have chosen looks OK but the two lines that you picked on the road don't look like they are parallel in the real world. I'd play with those a bit.
Edit: One thing to be aware of, if you go back to that site, that same car and road are in several different backgrounds already. So, it's a composite and not from a real world photo. That means, you can't trust the perspective and vanishing points to be real or correct. It's unlikely you'll ever get a perfect camera match regardless but by playing with it, you can certainly get something "good enough" for what you need.
When there are no clear perpendicular lines in the scene, you have to get creative and be the artist. Just keep aligning it until it's close enough to looking good in whatever you do next with it. You'll likely have to do it or fuss with it a few times.
Edit: Something to be aware of. If you go back to that site you'll see that same car and road in several backgrounds. So it's already a composite. That means you can't trust that it has proper or real vanishing points. Meaning, you'll likely never get a perfect real world camera solve from it. But, you can push and shove on it and get something good enough for what you need most likely.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
