Help with Seams - Unwrap UVW
Hello, I have a Unwrap UVW modifier applied to an editable poly object. I used point to point seams to create the seams I wanted. There are a few seams I would like to change, how do I remove a certain selection of the seams that I want to remove?
Thank you,
Sherie
blakestone
CTRL: Adds to the current selection | ALT: Removes from the current selection
Hello Blakestone,
thank you for the reply. I am wanting to remove a seam that has already been created and the file has been saved. I am not currently in the mode of adding the point to point seams, so I do not think your instructions will work, will they? Just in case I did try anyway, I have my point to point tool selected and I attempted to hold down control and click on the first part of the seam I want to remove but nothing happens, it does not remove the seam.
Also the images you added, I am not able to make them big enough to be able to see what your pointing to, is it the way you have added the image or do I need to do something special to be able to make it big enough to see?
blakestone
The step I missed was to enable "Edit Seams"...
Here is a video I've just recorded to demonstrate this: http://youtu.be/PH10YcErbJQ
Perfect! thank you so much Blakestone, appreciate it 🙂
Lo que a mi me funciono es con la herramienta edit seams, seleccionas la linea de mapeado que desees borrar mas la tecla alt y listo.1.png
Thank you!!
