Help with chamfer function
For a course, I need to create a wardrobe with rounded inner top. The first steps work :
- I create a box
- I transform it to become a poly
- I switch to edge mode to select edges to create more connection point with ring and connect in order to create a polygon inside one of the faces.
- I go to polygon mode to use extrude in order to compact the face of the cube to the bottom. I make attention to not create z-fighting.
- And there, I'm stuck.
- I have the impression that I need to add vertex at the inner top center so I will be able to move it and create inside an angle. Afterwards, to create the angle, I move the vertex on the Z axis.
- Now,  I try to use the chamfer function in edge mod to round the triangle to create a rounded top. But it become a horror of impossible form.
Can you help me ? Point to me my error ? Or a vid ? Or a tutorial ?
The linen closet should look like that :
Hey,
I would be able to help you out more if i had an image of what you have now.
But here a video on how to use the chamfer tool.
https://www.youtube.com/watch?v=Ix7NFv3JEXE
Fadhil_Farook
Check out the screencast I made. I did the whole thing because I couldn't quite comprehend what you were trying to imply when you made the post.
Thank you, Fhadil_Farook. This tutorial was perfect.
