FFD(cyl) 2x6x4
FFD(cyl) 2x6x4
Message 1 of 15
FFD(cyl) 2x6x4
Getting familiar with the workspace and modify assets. I'm trying edit the "Set Number of Points" on an FFD(cyl) modifier - I'm trying to set FFT Dimension to:
Side: 2
Radial: 6
Height: 4
The default side is 6, and I can't edit this to change it to the desired amount. I'm not sure what I'm missing?
N.B. Not sure if I'm posting in the right thread.
Replies (14)
Message 2 of 15
Steve_Curley
No quite sure I understand the question. Change the numbers (sides/radial/height) then click OK. They are not "parametric" in the same way as the initial Cylinder object - it won't update on the fly, you have to click OK.
Probably not a good idea to change those after modifying the model using that Modifier - you'll likely lose the changes.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 15
Hi, thanks for the response.
With regards to changing the dimensions. Yes, they are not constrained values. I'm working from a reference that follows the steps:
"Go to 'Modifiers' list select 'FFD(cyl)' tool. Click 'Set Number Points' and change 'Dimensions' to '2x6x4'"
I'm adding the modifier and setting the parameters. As far as I can tell from the documentation, unless I'm using the preset FFD modifiers: FFD 2x2x2, FFD 3x3x3, FFD 4x4x4 etc. I should be able to edit the dimensions?
I'm beginning to wonder if my not being able to do so is a result of altered preferences or settings that might affect this modifier.
Message 4 of 15
Steve_Curley
The FFD (box) and FFD (cyl) are the only ones where you can change the number of points. Are you saying that you physically cannot alter the 3 numeric values? Have you tried using the Spinners (the up/down buttons) rather than trying to type in a number? If neither are working then they're likely not working anywhere else, and yes - you then have a real problem and it may be down to corrupted settings.
[edit] Whatever the "reference" (or indeed Max itself) says, (for the FFD(cyl) they are NOT dimensions - they are simply the number of control points in the specified direction. The size (actual dimensions) doesn't change, only the number of points.[/edit]
Max 2016 (SP1/EXT1)
Message 5 of 15
Si, si, I only refer to the label "Dimensions". The reference and documentation I'm refering to highlight that they are simply the number of control points.
I get the same result clicking the spinners - nothing.
This totally sucks.
Message 6 of 15
Steve_Curley
Regretably I still don't understand your problem. Look at your original image. On the right (in the stack rollout) it says "Dimensions: 4*6*4". Those are the current, existing values.
Now look at the dialog on the left - the values are clearly 6*6*4. so you CAN change them but you MUST click OK before those values will have any impact.
Max 2016 (SP1/EXT1)
Message 7 of 15
The values appear to be constrained.
I'm trying to change my "Side" to a value of 2, that is, a value less than 4. At the moment I can only increase this value - it only accepts a value higher than 4.
I have no difficulty changing the values higher than 4. I can select OK and confirm any values higher than intended. My issue is that for the "Side" value I'm not able to edit and confirm a value of 2. At the moment any value added less than 4 is void. Confirming, or clicking OK does not confirm an edit of an integer less than 4.
Apologies for being unclear.
Message 8 of 15
Steve_Curley
Ok, now I see what you're after. On my system Sides won't go below 6 (Radial and Height both go down to 2). Not sure why you would want 2 sides - there'd be no space between them - like a page of a book - a thin sheet. Not much use for deforming a cylinder... An absolute minimum would be 3 as that's the smallest number of sides which can enclose a volume - 2 can't.
Max 2016 (SP1/EXT1)
Message 9 of 15
PROH
Hi. If you look at Steve's picture, you can see that in the stack roll out, the "side number" is the second number. So setting the Dimension to 2x6x4 = 6 sides. Your mistake is caused by inconsistency in the way the numbers are displayed in the stack vs. the dialog box.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Message 10 of 15
Appreciate the responses.
@PROH The inconsistency with the values isn't my primary issue. It's that whatever value I changed it wouldn't change to the intended value - if that makes sense.
@Steve_Curley The restraints are duely noted. I'm being slighty contemptful here, because I'm only attempting to change the values to the specific values:
Side: 2
Radius: 6
Height: 4
Because I'm following a tutorial that demos this as working, and insists these values are necessary and possible. If this is simply something that cannot be done I would leave it at that.
"An absolute minimum would be 3 as that's the smallest number of sides which can enclose a volume..." - I'm unable to do so.
Sorry, I feel this question has sparked more frustration than anything; I apologise for my lack of clarity.
Message 11 of 15
Steve_Curley
Is this a paid-for tutorial? If not, please post a link to it.
I didn't say it would go to 3 sides, I said the absolute minimum number of sides required to define a volume of space is 3 (think an extruded triangle). The minimum number of sides in the FFD (Cyl) is 6 - you cannot change that to 2.
Also, what version of Max are you using? I'm using 2014, this may (and I stress may) have been different in earlier versions. I pretty much never use the FFDs so I can't remember.
Max 2016 (SP1/EXT1)
Message 12 of 15
PROH
Hi. I honestly believe you're missing my point. You wrote:
I'm working from a reference that follows the steps: "Go to 'Modifiers' list select 'FFD(cyl)' tool. Click 'Set Number Points' and change 'Dimensions' to '2x6x4'"
Assuming you wrote correct, then my point is that 2x6x4 means: Radial = 2, Side = 6, Height = 4, and that you are not beeing asked to set "Side" to 2.
Regarding how low numbers you can set, I can confirm that the lowest possible setting for the FFD(cyl) is 2x6x2. Meaning: Radial = 2, Side = 6, Height = 2.
Hope my point is clear.
3dsMax 4.2 to 2018
Message 13 of 15
Ah, I've been confusing myself, thank you!
I made something simple complicated fjhkisd (  > _  <  )
Thanks!
= (  ^  _  ^  ) =
Message 14 of 15
Apologies for the misundertanding.
Message 15 of 15
Steve_Curley
No worries - main thing is that we got there in the end 🙂
Max 2016 (SP1/EXT1)
