Edge is locked on an axis
Using 2010. I'm trying to move an edge on the Z axis, but for some reason it refuses to go that way--nothing happens when I try dragging it down, and dragging it up causes it to go forward on the Y axis. This happened when I pressed something wrong on my keyboard I think, but I have no idea what. Resetting, restarting the program, etc doesn't work.
A few questions:
- How do I fix this?
- How did this even happen? When I google ways to lock vertices/edges/etc, people are saying it can't be done
Thanks for any help!
blakestone
Did you maybe hit "X" on your keyboard, which locks gizmo ? If so hitting "X" will enable to gizmo again.
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
Steve_Curley
"X" only hides the Gizmo - it doesn't "lock" it or prevent you using the toolbar Axis Constraints 😉
A more likely suspect is the "Constraints" section at the top of the Edit Geometry rollout. Make sure it is set to "None".
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
