diagonals on mesh in viewport (problem)
I have these diagonals showing on my mesh-objects -
How to get rid of them?
Thanks.
blakestone
Try the Quadrify feature in the Graphite Toolbar... note: only works with Editable Poly objects.
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
Not true at all - I find the answer in other sites and I'll post it here too.
I manage to pinpoint the bug here:
Customize-Preferences-Viewports
at [Display Drivers] click btn [Configure Driver = Direct3D 9.0(NVIDIA GeForce  ****)]
it appear "Configure Direct3D" window.
up at [Geometry] uncheck - Display All Triangle Edges.
PROH
Hi. The problem you asked about could be caused by several things. So that the problem in your specific case was caused by a setting in the graphic driver doesn't mean that blakestones advise was "not true at all". In fact it was a very good advise for the most likely cause to your problem - especially since you gave us very little information.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
