Decimal problem
Decimal problem
Decimal problem
Hi, I'm on 3ds Max 2017 and I'm having an issue I've never had before When I'm doing something like chamfering or insetting and I manually input a number after the comma it gets pushed back to 0,0 every time:
 1676bdb32c815292d97ffcf23769ebe7
It's the same whichever units I used, whether centimeters or meters. I'm on a French PC so we use commas. If I manually replace the comma with a period it works but as soon as I pan or orbit around, it gets pushed back to 0,0 again.
I've tried the SP1, SF 2017.1 but it's the same so far.
jackietsteh
Hi may i know how you create the animated image?
Best regards,
Jackie Teh
Portfolio: http://www.coroflot.com/jackieteh
Youtube Channel:https://www.youtube.com/user/jackieteh
don_3259
i think there is some problem in that copy of 3ds max try to install 2018 version then reply...thanks
i have 2017 not getting this issue
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
jackietsteh
Try click the two arrow once, then try to type the number you want to input...see whether it work or not...
Best regards,
Jackie Teh
