Create shapes problem
When I try and create a shape from these 9 edges, the object doesn't appear, I feel like it has something to do with Enable in viewport but I do not know how to fix it, thanks!
 https://gyazo.com/db1574e08e78210bdf552e5a9103de48
miledrizk
Actually the shape is created and it has a light green color,
All you have to do is get out from the Sub-Object level, and pick the shape
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
I appreciate the reply but I'm not completely sure of what you meant I'm not that good with 3ds max, did you mean that it should be in my list of objects now? If so, I didn't manage to find it
miledrizk
I made a quick screenshot where i do exactly what you did,
But before watching the clip i need you to go to Display panel and make sure
The Shapes option is unchecked. Because if it's checked then you'll not be able to see 2D
Shapes in the viewport
display.PNGCheck the 2D shapes visibility in Viewports
[email protected]
Thank you so much! So glad a 3ds max veteran could come and help 🙂 Keep up the good work!
