Connecting splines to create a shape
sburkeW2VGV
sburkeW2VGV
Hey guys. Another noob question. How to connect these splines to create a surface between all of the shapes? I want to make a bathtub this way. Cheers guys!
there is lots you can do to build lines into sculpted object by adding a surface modifier on top of a crosssection modifier.
I kept a complete stack of modifiers where I:
drew 2 rectangles and 2 elipses,   In each form (rec, elip) i "Attach" each to its similar other, then add Crosssection and Surface.  I then used a Boolean Compound Object to take that square outer solid and "Subtract" the eliptical inner object.  I probably could have used Pro Cutter or ProBoolean but I'm less experienced with these.
sburkeW2VGV
Thanks man! It was more simple than i thought. I used crosssection, and i got exactly what i wanted.
