Boolean issue
Boolean issue
Message 1 of 16
Boolean issue
Tried all forms of booleans and proboleeans. Cut, subtract, everything. Both objects have been tried with mesh, poly, 1 poly the other mesh...
Really don't know why the boolean "cuts" the first object, instead of slicing the chunk I need
Any tips?
https://www.dropbox.com/s/6zyt6kst24ls63p/1.jpg
https://www.dropbox.com/s/lzpmp8zkkl23tam/2.jpg
Replies (15)
Message 2 of 16
PROH
Hi. Max has never been as good at Boolean operations as i.e. AutoCAD. In cases like yours I can think of 2 major reasons to fail:
1) One or more of the object are not enclosed. Make sure they are all welded and without any holes.
2) The complexity of one or more objects are to complicated for Max to calculate it correct.
If it is not possible to get Max to do it right, then you'll have to manually remove the unwanted faces and bridge the gap.
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Message 3 of 16
1. I'm pretty sure it's closed. Made a spline, modded to poly, then extruded it to make it 3d. How can I confirm this?
2. Possible that it's too complex (10k polys). Not going to do it manually, so any easy way to "dumb down" the polycount? Wouldn't want to restart everything
Thanks!
Message 4 of 16
Steve_Curley
It would help enormously if you could post the scene - just the objects involved in the Boolean operation (before you boolean them, of course). Zip the .max scene file and attach it to a reply.
I just made a rough equivalent of what's in your 1st image and using ProBoolean (Intersection) it correctly "cut out" the shape of the central object (pink) from the 2 white objects (which in my case were a single object - 2 sub-splines + an extrude modifier).
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 5 of 16
Here you go. 2 versions of the same models. Thanks for the help.
Message 6 of 16
Steve_Curley
Line013 and Line 014 are open - there's no poly on the one end. Those will need Capping at the very least.
I still can't get the Boolean to work correctly - I'll look properly later today (busy busy...).
Max 2016 (SP1/EXT1)
Message 7 of 16
Steve_Curley
I'm at a loss trying to get the imported objects to boolean correctly at all, yet if I re-create the Line013 object within Max it will boolean perfectly with the imported Sphere003. I have a suspicion it is to do with the relative mesh densities of the 2 objects - the number of vertices used to create the curves, because when I recreated Line013 I did so with many fewer vertices and used the Bezier Tangents to recreate the curves. This is somewhat confirmed by using the Section Shape to create a Slice though Line003 - adding an Extrude to that shape fails to cap the ends. My modified shape however extrudes correctly and booleans correctly.
Working Boolean
Left image is the original section (left) and mine (right). Middle image shows the result of adding an Extrude. Right image is the result of a ProBoolean (subtract) with Sphere003.
Max 2016 (SP1/EXT1)
Message 8 of 16
I see, so the problem was that the spline was created poorly from the beginning. Ok, will re-study the basics and then move on.
Maybe creating a simpler line, boolean, then apply some chamfering to smoothen out?
THanks a lot for your time, Steve!
Message 9 of 16
Steve_Curley
Not poorly, just too complex for the Booleans to handle (it seems).
Simpler line yes, but if you do it carefully you should be able to match the original curvature very accurately so removing the need for Chamfers later (which have their own problems as you'll no doubt discover 😉 ).
Max 2016 (SP1/EXT1)
Message 10 of 16
So how would you make a perfectly smooth curve in that part of the mesh? just 2 normal beziers and 2 bezier corners?
Message 11 of 16
Steve_Curley
Effectively yes, as that's how the Section shape created the Spline I worked with.
I removed all the vertices defining the curve except for the 2 endpoints (obviously) and one at the center of the curve (converted that one to a Corner). I then used Fillet on that middle one to give a close approximation, then just moved the 2 vertices created by the fillet, and their Tangent Handles, to get the final result. I did it by extracting the Shape twice so I had the original to work to as a guide. The differences were very minimal - I had to zoom in a long way to see any divergence in the splines - and I didn't spend too much time doing it as I was testing a theory, not my modeling skills 🙂
Max 2016 (SP1/EXT1)
Message 12 of 16
Beautiful, thanks again!
Message 13 of 16
Solved in a matter of 2 minutes: new line, bezier, close it, convert to editable poly, extrure to one side, cap the other, boolean, done
Had my basics wrong, overcomplicating something that takes no effort
Message 14 of 16
Spoke too fast. During rendering it clearly shows that chamfer and splines are not smooth enough when curved.
ANy other solution? Something like turbosmooth on just a few faces and not all the poly/mesh?
Message 15 of 16
Steve_Curley
Try stepping back into the Editable Spline and increasing the number of Steps (Interpolation Rollout). Don't go mad with it though as you might run into the original problem.
Max 2016 (SP1/EXT1)
Message 16 of 16
if it's possible to detach the part that you gonna boolean max has less to calculate. then you can attach it back when you'r done
