Bitmap brightness
Bitmap brightness
Bitmap brightness
Good afternoon, I'm having problems with the bitmap, when I select the bitmap in the editor material, it appears half dark than the normal image, how to solve?
This could help
https://youtu.be/IIskRcA6ffs?t=164
basically set self illumination 100
Also start with a clean bitmap map node to ensure that it has default settings. I suppose you are using a bitmap map node and a standard scanline material, you don't need anything else for a reference plane.
