wire parameter refresh
would be nice to get a more fully fleshed out wire parameter dialog box and tools.
it would be nice to be able to identify when a wired parameter is broken...for example  a working wire, one side is red text  and one side is green text. but if the wiring breaks in an uncommon way, one side of the wire will stay red but you wont know that its broken from its other half. maybe if a wire gets disconnected incorrectly the node's text turns yellow as a warning identifier.
ex. if a layer is frozen it doesnt show up in the wire parameter box even though it is selectable in the explorer.... so maybe make a way to notify people that something IS frozen, or a way to turn it on off, or maybe dont make frozen layers affect wiring.
the way it finds/displays the connection wire is a bit obtuse and cumbersome too. so maybe that could be optimized and rehauled.
im sure theres lots that can be integrated and improved on within this max feature.
thanks!
2 Comments
sebastian___
It needs to be turned into a node based thing. Either a general node based editor for everything in Max, like Zookeper, or at least one just for the wiring.
absolutely!
