UVW Map Modifier Update
I would like to see and update on UVW Map Modifier, That makes it easy to apply a texture on a curved model, For example, a curved roadway.Capture 2.JPGCapture.JPG
7 Comments
Max has this for a long time...
What I meant is to be added to UVW map modifier as a custom shape for an easier application
michael_spaw
+1, please add any details as how you might like this to work.
-Michael
Kelly_Michels
Mr. Michael
I think one option can be added to the mapping options listed above, To be " Custom or Splines"
So the mapping shall follow the spline shape.
Regards
ME
RGhost77
Old plugin Texture Layers 2.0 has uvw map by spline. TL2 was released as open source, so maybe ADSK will find easy to contact with author and use part of code of TL2, than write this mapping type from scratch...
Tupaia
The algorithm could work like this: for every mesh vertex, find the nearest point-on-spline, then apply cylinder coordinates according to that spline point. It's the users responsibility to create a spline that is as congruent as possible to the mesh. (For a lengthy object like a road, a spline could easily be extracted from an edge-loop-selection along the length, of course.)
