Transformation ToolBox combined with Scale Transform Type
Cmon guys! 🙂
We need to have a real fast way to scale transformation!.....
Transformation ToolBox needed to be combined with scale Type In interface! ... I have request differents betas ago but nothing changed!
Many people ""NOT KNOW"" the esistance of Transformation ToolBox!!!!! .....
One interface is the best way to reduct clicks, windows.... and pain!
Thanks!
3 Comments
michael_spaw
+1 Some love should be given to the transform type in for sure!
-Michael
Kelly_Michels
markus
Is it just me or does the transform toolbox lack the option to scale/set size of on object uniformly based on one dimension?
If I type in X it will only change the X dimension, resulting in a non uniform scale. If choose "all", it will set the size of all sides to the value given, but unless your object has the same height with and length, this will also result in a non uniform scale!? I understand that you can calculate each dimension manually and type them in for each dimension, but that feels like a lot of unnecessary steps for the user.
I would suggest you add a uniform scaling option, based on changing one sides dimension!
