This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Tab into edit mode (like Blender)
This may be a controversial one, but I quite like Blender's 'tab into edit mode' paradigm. I sometimes accidentally exit out subobject modification by pressing the numerical key corresponding to the current object level (e.g. "2" for edge when in edge mode). By adding the option in the user preferences to enter/exit subobject mode with tab only this would save a little bit of time for each accidental exiting and re-entering subobject mode to continue modeling.
2 Comments
Swordslayer
There's already the Sub-object Selection Toggle (Ctrl+B by default, but you can map that to Tab if you want) to enter/exit the last active subobject mode. Together with the 'Multi' preview selection mode that takes you to the matching subobject level depending on whether you clicked a vertex, edge or polygon, that's all you'd need.
Also, if you're accidentally exiting subobject mode by pressing the same key twice, you could just as well remap the shortcuts from subobject level toggles (enter/exit) to non-toggle shortcuts (enter only) – if you can't find them, you can just type subobjectLevel = 1 and select+drag that text to a toolbar to create custom macro for that in drag&drop category (you can then delete the button from the toolbar) and assign that as vertex mode and repeat for other modes/numbers. To exit the subobject mode (since you'd now need that as well), you'd use Object Level shortcut (or 0 for subobjectLevel value).
Intuos5
For those who are interested, a working script to achieve this proposal can be found here: https://forums.autodesk.com/t5/3ds-max-programming/tab-into-edit-mode-like-blender/m-p/9696958.
You can then map 1/2/3/4/5 to the subobjectlevel commands in the Hotkey editor and Tab to objectlevel (this is also a default command in 3ds Max, so it does not necessarily require the first script).
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
