Show only
Search instead for
yes, need people to find more cases when it fails to be refined to perfection.
And yes, similar to uniting multiple cut and loop operations into a single tool the same approach should be with the extrude operations, in this case adding the hinge from edge
It would also be nice if it could do an Inset when using the Scale tool rather than a simple scaling toward the selection center. Maybe with an added hot key like Ctrl while holding Shift.
anyone knows a better way of hinging extrude from the center of the polygon without the the the workaround of temporarily adding an edge in the middle of the polygon then performing two hinges from edge operations, both from this middle edge: one with positive and the other with negative value than deleting the created edge.
