separate files in one instance
We really need to have the Detachable Viewport and the ability to upload multiple files in the same instance of max. Copy, paste, xref would really fluid.
10 Comments
michael_spaw
Can you please spell this out a little more? How do you see this as being different than this idea?
https://forums.autodesk.com/t5/3ds-max-ideas/viewport-tear-off/idi-p/6738064
-Michael
Michael Spaw
3ds Max, Product Owner/Designer
Media and Entertainment Division
passariello
My idea is a bit different:
passariello
It's necessary to have a robust interchange cache file for copy / paste of object like XML or better .... JSon
.... work is possible if all information is stored in a part of memory / file (as cache) that pilot all information....
Users are convinced to work in multiple file but for DEV is an only one unique file.
passariello
The file multi istances will .MAXPROJ file (like compile software) that comtains all project.
Files remains individuals "A.max", "B.max".... and will updates on save or by requests-
In this case the amounth of devs recompiling is on the part of actual software deputate for load, merge, save, combine....
For viewport the major changing will on division to windows were software use as "internal istances" and are separated job for OS and GPU.
Make sense?
michael_spaw
Thanks for the additional information.
electrotoast_old
@passariello If you can edit it, remove the "detachable viewport" as part of this idea. While I get the Idea in general, they are two separate things and I'd hate to Achive this one as it's not exactly a duplicate since it has the additional info. If you can't edit, let me know and I'll edit it.
passariello
I'm really sorry but I don't have opportunity to edit it 😞 ...
electrotoast_old
I was able to update it. Thanks for the Idea!
electrotoast_old
passariello
THANK YOU GUYS! "Future consideration" is a great news for me! :)
