Selection with move tool
Ideally when selecting polygons,edges or vertex it should behave as it does in Maya. You can only move them by translating the gizmo. Also when moving a polygon,vert,edge the gizmo should move with the mouse not update after.
This works flawlessly in Maya. Wish it would do the same in max.
5 Comments
yeah thats a very weird behavior
ahmed.fawaz7h8fs
Please implement this even as an option
js-gomez
I've been wanting this for so long. It would really help those who want to use 3ds Max with a graphic pen like me.
perprerp
I suggest that this problem has the same underlying cause as and should be merged with the following https://forums.autodesk.com/t5/3ds-max-ideas/stop-max-changing-from-select-tool-to-move-tool-when-le...
small but  aserious missbehaviour, same as the issue of max switching to move tool instead of selection when exiting some tools (as reported in the other idea suggested above)
