Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Repeat last command
Repeat last command
Is there a way to repeat your last command or action inside of 3ds Max? I know you can repeat your last command inside of edit poly, but I haven't found a way to do this with other tools, or inside other editors such as the UV editor. I know Maya already has the G key shortcut that repeats your last action, but it would be really useful if 3ds max could integrate something like this. This would certainly make my workflow more efficient for things like UVing where you are repeatedly using the same tools over and over again. For example, Instead of having to move over to the UV editor and click on let's say the relax tool, I can simply hit a shortcut on the keyboard that will repeat my last action without having to leave the viewport or your place in the editor.
Dani
3 Comments
nuno_moser
I don't think there is but it would be useful... I support your idea!
Thanks @DaniSan_2, this is an interesting idea.
nadia.miltcheva
This is a must, Why isn't it integrated yet Autodesk?
