This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Point Caching geometry with changing topology
Add the possibilty to create point cache for changing topology objects, like complex particle flow system, for example. The integration of the XMesh plugin would be perfect!
7 Comments
DaveWortley
Have you tried using Alembic? You can also use Performance Mode with the Alembic Helper to play back massive caches in the viewport.
But I agree it should be easier to cache something... the work under the hood is there, just needs better workflow.
Guillaume.BrXYZ
Hi Dave, I tried Alembic yes, but point caching complex particles systems for example is still way too complicated!
eugenio_miolo
Maybe add support for alembic in Point Cache modifier and the Cache operator in PF.
michael_spaw
Thanks! Would be interested in what specifically you think is too complicated about using Alembic. Details will help a lot.
-Michael
Kelly_Michels
Guillaume.BrXYZ
It would be great to be able to generate a file per frame actually. When you have to network render a very heavy particles sequence, it is not really handy for all the computers to load/unload the same and only heavy .abc or .vrmesh file for example. I don't even think it is possible (in 3dsMax 2016 at least) to export a pflow particle system without "baking" it in 3dsMax... Baking a particle system with instanced animated particles would be a very great and useful feature IMO! Thanks
electrotoast_old
