Plug-in to easily model and animate Chains and synthetic slings in the construction industry
There need to be a way to better animated chains in 3dsmax than using MassFX as the animation of the chain links begin to jitter uncontrollable.
When making slings I use the loft function and then use the twist deformation, this looks great for stills but the twist deformation doesn't work once the loft spline is animated as the control points for the twist move. There needs to be a way to lock these points.
