Option of adding a disabled modifier
Add the possibility of adding a disasbled modifier. This way it is possible to edit the settings before enabling the modifier. E.g. adding optimize modifier 3ds max calculates the modifier, then after editing settings the modifier is calculated once again. By adding a disabled modifier the settings can be edited and only calculated when enabling the modifier.
1 Comment
you can add a "disabled" modifier already...
	m = edit_mesh()
	m.enabled = off
	addmodifier $ m
