Non-modal Align dialog
Currently, the Align dialog (default hotkey: Alt-A) is modal, i.e. you cannot do anything else in 3ds Max until the dialog is closed. It would be helpful to at least be able to use viewport navigation while the dialog is up, in order to check the result of the X/Y/Z/min/center/max options by arc-rotating the viewport.
4 Comments
Swordslayer
Agreed, and the exact same situation is there with the 'Normal Align' dialog.
brentscannell
lightcube
Yep.
what other dialogs are modal in 3ds Max ?
