Merge by Layer
Merge by Layer
It's crazy that Merging a File is so limited in terms of understanding the scene.
I want to be able to merge and add Xref Objects based on Layer.
See my other post for allowing API for .max files to know layers are in the scene.
10 Comments
 I have the same issue!
When I open the Merge Dialog, I want to be able to see the Layers of the Objects that I'm merging, so that I can quickly merge Objects from specific layers. Otherwise, with large scenes, you have a huge list of objects all jumbled together. Unless you give the objects names that also refer to their layer, then it's very hard to sort through them when merging.
Seems after so many years of evolution Max would have sorted out this kind of basic functional flexibility...?
@DaveWortley Did you ever find a solution to this?
People have been asking for this for at least 10 years... probably longer.
And there have been many new versions of Max in that time.
Deaf ears at Autodesk?
dbhinnant
Absolutely!  It's a nightmare to merge objects from a team member who has not meticulously named all of their objects.
sconlogue
I want Merge by Layer like I want a Porsche 918. Question is, which will happen first.....
Kelly_Michels
electrotoast_old
joeaf9321
Hope to see this feature soon.
I DEFINITELY hope to see this in 2021, it's a must have feature honestly, honestly right now organizing in 3DS Max is a mess when working in multiple file types.
I would really like this feature to be added, it would have been som much easier to merge a file from a large scene with tons of files, at least being able to sort by layer in the merge menu
Ehsan.Sarahian
This's a good and practical idea. I hope it will add to accepted autodesk list soon.
