Make Autosave Efficient
When you have a heavy scene the autosave function locks up  max and interrupts your work flow. Also sometimes it starts to save when you are in the middle of a complex setup which may lead to a crash. It would be great if the auto save happened without affecting the current session of max.
95 Comments
dwortleyPT6GS
My worries with putting in a Autoback which kicks in after X seconds of inactivity would mean that a modeler or someone working hard for an hour could easily lose their work if Max crashes after a whole hour of modelling.  I've done client remote sessions lasting hours where we're constantly tweaking cameras, moving objects around.
Also, if you work for like 10 solid minutes on something, then jump over to another application to respond to a quick email or chat message, your max will lock up doing an autobackup and you'll have to wait to get it back.  I'd find that more annoying.  At the moment if you're working and you want to stop an autoback you can tap Escape key, however it doesn't always work.
Background auto-saving would be the best thing but as I understand it, it'd be quite tricky to implement at the moment.  I always encourage people to use VRMesh/XRefs etc to keep their working file as light as possible so autoback times are quick.
Some quick fixes that could be implemented would allow better performance with Autoback.
a) Changing scene/object selection should not set dirty flag.
b) Modal dialogs should block autoback, this should stop when the Escape key doesn't work.
c) There should be a 10 second count down before an Autoback down in the status bar where it says "press escape to cancel autoback"
d) When max is idle, when it autosaves the next autoback timer shouldn't start until the scene is next dirty... this will stop the annoying thing when you have an idle max session for hours, then as soon as you touch something it wants to autback again.
e) playing animation should pause autoback timer
f) SDK/Maxscripts methods for pausing autoback timer for certain things like IPR or simulation
g) Disable File Metadata Stream writing in Autoback files, it's really not needed and can speed-up saving quite a lot.
h) Escaping X number of Autobacks in a row should flag to the users, So many times I've escape 3 in a row for max to then crash.
danny.austin
I think these suggestions would mitigate the problem a lot until a true background / non-interruptive autosave is implemented. Thanks for your input.
shawnolson
Status changed to: Accepted
alex
Great to see this is now "accepted"! Any details about plans/specifics/timings?
shawnolson
@alex We generally do not give timing on our upcoming releases. I can tell you that one of our teams has already been actively working on this. If you would like to see the current progress you can join our 3ds Max beta program.
alex
@shawnolson thanks, great to hear that. Fingers crossed this makes it into a 2022 point update just maybe...
michaelbrecker
Observer
Very good idea, thank you for considering! 🙂  banks-near-me.pngbanks near me
alex
Would it be possible to get an update from Autodesk on progress of this?
danny.austin
Yes, @shawnolson  very eager to hear of any progress here. Are you able to point us to a change log or road map for the development in this area?
Also, do you know if any users have been consulted in the process of working on a solution here? That would be a real step in the right direction.
Implemented in 2023.0
shawnolson
shawnolson
Autobackup was updated in 2023 to be more efficient and less intrusive: https://help.autodesk.com/view/3DSMAX/2023/ENU/?guid=GUID-1AA91F8A-CA4E-4432-9D54-1301305CB44C
alex
Hi Shawn/AD,
Appreciate the update, and the progress with Autosave has been welcome, but the absolute main thing for us still remains "unimplemented": background saving! The current/new system is indeed an improvement, but it's been almost 7 years since this original request and AD have not managed to find a way to get Autobak to work in the Background like Photoshop does...
I don't think it should be beyond the realms of possibility for a team like AD to figure this one out over 7+ years, all things considered.
jedchambers
Hi Shawn,
Thanks for the update and appreciate the work that has gone into improving this feature.
If and when can we expect a non-intrusive autosave? We are all paying quite alot of money for using this platform and dont seem to be getting many of the actual improvements that are regularly being requested....
jibijib
This works great, I don't even notice it autosaving - I would say this has been implemented perfectly without any flaws, thank you Autodesk Devs!
