Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Improve snapping modes
It would be useful to add some new snapping modes to facilitate precision modeling :
 - Snap to intersection : this should work both for shapes (snap to intersection of lines) and geometry (snap to intersection of edges)
 - Make Perpendicular snap work with geometry objects to be able to snap to faces and edges
14 Comments
lightcube
Snap to Intersections is something I've wanted since before Dinosaurs walked the Earth.
Just add all the Snap from AutoCad.
I miss also the snap at the extension of an edge.
eugenio_miolo
-Snap to intersections: To work with any kind of intersection e.g.: line-line, line-edge, line-poly, edge-poly, poly-poly (snap to the line of intersection).
-Snap to Bezier Handles: That wouldn't hurt too.
I don't think snapping to the extension of an edge is feasible on meshes. Looks like it would be too slow and too messy.
Swordslayer
Also see VGSnap (some examples on how those snaps work are on the page):
twops_ui
clemens_at
also in this context:
improve snapping performance.
with high(er) polycount snapping becomes a real hassle even if zoomend in close with only a fraction of the vertices left.
im sure there is an adaptive way to handle this.
michael_spaw
Great suggestion.
-Michael
Kelly_Michels
JezEmin
VGSnap costs ยฃ40 and it Intersection (which is what I want) only appears to work at a sub object level (not what I want - I want it to work for any object / across objects etc).
Br0ken1334
Snap to Polygon Center is very much needed. Strange to see that Face Center snap is available, but Polygon Center is not.
doomgravex
Great Idea!!!
doomgravex
Agree that also Polygon center it's needed.
Triangles centers it's so useless
darawork
Voted. Snapping in 3DSMax is a leading cause of Tourette's syndrome.
joeaf9321
Also can you add a way of using the scale tool with snapping? Like whe you have take your selection and from on of the vertices that belongs to that selection you start to scale and then that you can snap it to Vertex and this affect the scaling.
Shirky27
Please overhaul the grid snapping to work like other modern modeling and real time engines. Current grid snapping only works only a single plane (perspective grid). Having a grid snap that works more like Maya, UE4, Unity, etc would be highly beneficial for structural modeling that needs to consistently be on the grid.
Essentially the gizmo will snap to grid increments regardless of the actual perspective grids position. Also works in local translation
