Edit Object Properties
This should be easy 🙂
The ability to change dimensions of geometry from with in the Object Properties. At least for Standard Primitives.
Furthermore it could be quite cool if some of the basic parameters for Standard Primitives or maybe Modifiers  - Turbosmooth/Iterations and such - also were editable from within the Object Primitives. At least some user configuration on what should be visible to edit quickly from within the Object Properties.
