Command Panel update
We have extra space on Command panel finally! But now lets use it! Some parts are more important than others, but everything should be updated, here the Motion panel, where we have to scroll unnecessary to see important information, make this adaptive so we can see all information!
5 Comments
So true.This bugs me for quite some time.
Other areas that could benefit, would be the morpher-modifier:
Or the Skin Modifier:
Sadly, STILL in 2020.1 the command panel resizing is broken. I always work with 2 panels, but often times and randomly the 2 panels turn into 1 big wide panel for no apparent reason and I have to stretch and squash it around until it returns to 2 panels. So tiresome now that I'm used to Blender 2.80's really smooth UI when dragging panels. The command panel concept is so good in Max, but it is in dire need of an overhaul and GUI streamlining. Scrolling is a pain and dragging/rearranging rollouts is a waste of time. It would be great if we could fully customise the buttons and rollouts in a drag and drop style like Zbrush.
This happens with the data channel modifier (depending on the the inputs you have active), and consistently with the path deform (non-WS version) modifier and chamfer modifier. And they all split into 2 panels at random points when resizing the command panel, too!
Data Channel  1Data Channel 1Data Channel 2Data Channel 2
the ribbon extra functionalities should be added to the command panel and get rid of that ancient stuff for good.
brentscannell
