The boolean modifier is nice, but there are missing features to use it in more cases.
- it should be possible (like in proboolean) do disable the update completly for the whole boolean modifier.
- it should be possible to re-extract operands as instances (not remove, but extract).
- an selected operand should stay visible during modifying (e.g. edit poly subselection modifying)
- BUG: when using "live reference" and creating a copy of the object with the boolean-modifier and also of the live-reference-objects the links should stay intact and be linked to the copied live-reference-objects.
- now the boolean get damaged an the operands are completly broken.
best regards,
Simon
