Add UV Mapping Length & Width Repeat to the Sweep Modifier
The Loft component object has always had UV length and width repeat options by default.  The Sweep Modifier has long been a replacement for Loft in my workflows, however it lacks the same UV mapping repeat options.  Given that sweep objects tend to be much longer than they are wide - UV length and width repeat could be very useful for creating tile edges, kerbing, brickwork etc.
4 Comments
electrotoast_old
Superla-Envoke
If you tick "Generate mapping coords" in Sweep, then add a UVW Xform modifier you can alter the repetition of the map, as well as rotation and offsets.
Hart3D
Thanks for the tip Dean! Will use that. I still think it would be good to have that functionality built in to the sweep modifier though.
awesome solid idea!
